xtrememac Posted December 6, 2006 Share Posted December 6, 2006 Hi there first of all is there a guide/faq showing what those numbers actually refer to? and secondly I'm downloading a torrent (final gear 10x11) with bitcomet obviously. this tracker: 'http://tracker.finalgear.com:6969/announce' gives a 'tracker connection error: 3' & sometimes 0 now when I open this torrent on the newly changed and torrent supporing Flashget 1.80 b2 I do connect to the tracker and see about 120 peers. Why does flashget connect and find peers whereas bitcomet 0.79 does not? (current retries: 17) both udp & tcp ports are forwarded to my local lan and is working.. i tried stopping and restarting the torrent.. no firewall.. logged in to bitcomet tcp/ip limit set to max.. etc. etc. DHT is enabled & gives about 30peers.. TIA Link to comment Share on other sites More sharing options...
kluelos Posted December 6, 2006 Share Posted December 6, 2006 The error codes come from different sources (none of them BitComet), so a definitive list isn't really feasible. Codes with 5 or 6 digits are usually WinSock errors, so a search of the MS knowledge base will give you those, just as an example. You may solve the problem by simply downgrading to a stable version of BC, though. Link to comment Share on other sites More sharing options...
