DHT
starain91
:unsure: i do not know if this is where this topic is supposed to be posted but to the point. In the Trackers tab it says that my DHT is disabled in user setting. Does anyone know how to turn on the DHT network in the user setting? I shall be greatful for any help given on DHT. Thanks!!
Starain
There are three places that DHT needs to be enabled
Preferences -> Advanced -> Connection [check] "DHT Network"
Preferences -> Advanced [check] "Add DHT Network as backup tracker"
If you have to change any of these settings you should restart Bitcomet for them to take effect.
Also right click on the torrent and goto properties, there you need to [check] DHT Network for that torrent.
If its a torrent from a private tracker then this option should be greyed out.
