Lavastine Posted December 9, 2006 Share Posted December 9, 2006 Alright so I downloaded and installed Bitcomet then this popup pops up and tells me i should instal a font pack for Bitcomet to run efficiently, so i installed it and now the text in some of the popup messeges from other programs is blanked out. does anyone has any idea how i could fix this problem? Link to comment Share on other sites More sharing options...
ekw Posted December 9, 2006 Share Posted December 9, 2006 U got owned by adware. My best choice is to scan your comp clean then reinstall bit comet. Link to comment Share on other sites More sharing options...
dawin45 Posted December 9, 2006 Share Posted December 9, 2006 first of all what version of bittcomet are you ussing? second? pop up messages blanked out?(from other programs) hmmm i don't know about this? Do you have a firrewall and a antivirus on youre computer? I really don't know any solution 2 this problem... Link to comment Share on other sites More sharing options...
kluelos Posted December 9, 2006 Share Posted December 9, 2006 BitComet itself should not require a font pack for any reason. I suspect you downloaded a hacked version that someone included adware with, and the font-pack was for the malware. I'd suggest you uninstall and delete BitComet, scan your system with AdAware and Spybot S&D, then download BitComet 0.70 from the primary site. You can find it here: http://www.bitcomet.com/doc/download-achive.htm Link to comment Share on other sites More sharing options...
