auto303615 Posted December 10, 2006 Share Posted December 10, 2006 Good Day All, I am trying to seed a torrent. I believe the torrent has been created properly because Bitcomet shows it active with the orange up arrow and I have been watching peer count slowly rise. Despite peers trying to connect the UL speed reads 0. The torrent has been active to about 30 minutes now and I still show a total of 0KB transferred. Is this a connection problem? I have another torrent on DL with 6KB down and 13 KB up. Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted December 10, 2006 Share Posted December 10, 2006 If you have the complete files in the proper location, upon starting the torrent, it should have begun to scan (hash, or rehash) the files. They should now read 100% complete, if they do not, then you did something wrong. You can try a manual rehash, but if it still reads 0% complete, then your files are in the wrong location. Suspect ps. I am going to change your user name, to remove the "@hotmail.com". I'm not accusing you of advertising, but we don't allow such names as most people that use such names are trying to advertise something. Link to comment Share on other sites More sharing options...
auto303615 Posted December 11, 2006 Author Share Posted December 11, 2006 The files were at 0%. I stopped the task and then did a manual hash. The files read 100% now but the UL speed is still 0 kB/s. Is there something else that I missed?? Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted December 11, 2006 Share Posted December 11, 2006 if they are at 100%, then you should be seeding. If you have other torrents running, then stop them. If you are releasing a torrent, you should always provide ALL your upload towards it until some of the peers can take over the seeding. Depending on the version of BitComet you are using, it may set priority to low for seeding tasks, so you would want to change that to the highest. Suspect Link to comment Share on other sites More sharing options...
auto303615 Posted December 11, 2006 Author Share Posted December 11, 2006 Thank you! That did it. Link to comment Share on other sites More sharing options...
