kruiser123 Posted June 24, 2006 Share Posted June 24, 2006 anybody have a suggestion on a good dvd burning site ive tried real player and winows media player but both dont work any suggestions Link to comment Share on other sites More sharing options...
bitdave Posted June 24, 2006 Share Posted June 24, 2006 What is your question? -are you trying to play a video on your computer??? -or are you trying to burn some videos to a DVD to play on your dvdplayer??? Link to comment Share on other sites More sharing options...
kruiser123 Posted June 24, 2006 Author Share Posted June 24, 2006 im trying to burn them to watch on a dvdplayer Link to comment Share on other sites More sharing options...
The UnUsual Suspect Posted June 24, 2006 Share Posted June 24, 2006 I would be glad to help, but need to know exactly what files you are using, and what type of disc you want to make. For burning disc images, I use Alcohol 120% or Nero, both are good products. If you want to encode the video to dvd format, then I need to know what files you have. Suspect Link to comment Share on other sites More sharing options...
ZikO Posted June 24, 2006 Share Posted June 24, 2006 I don't have clear idea what yopu want to do but I assume you want to have real DVD. It is not as simple as you think, though !!! I assume you are going to have DVD with Movie like "Braveheart", if you like, the disk which you put into DVD Player (standalone) and watch your DVD. It's not about DivX, which most DVD Players can afford now. However, there are vast number of programs which you can use. Some of them are: Pinacle Studio, DVD Lab, DVDMe (If i remember correctly) and many many more. http://www.dvdrhelp.com/ http://www.doom9.org/ These websites are for you and go there at once and start reading these. Simply speaking, DVD Lab / DVDLab Pro, for example, is one of the vast number of programs by means of you make image of DVD, because the point is to make image of DVD and then burn it by any standard program you like!!! This program makes VOBs files and those file you can burn by Nero just showing that you would like to burn DVD Video. That type of DVD disc you can put into your DVD Player (standalone) and watch the film like any commercial movie. However, you need to have MPEG2 to make DVD disc, but you will know it when you go through those webs. Link to comment Share on other sites More sharing options...
caf4926 Posted June 24, 2006 Share Posted June 24, 2006 kruiser123 said: anybody have a suggestion on a good dvd burning site ive tried real player and winows media player but both dont work any suggestions http://www.videohelp.com/tools Link to comment Share on other sites More sharing options...
