Help with Download
Good Day to all:
I am really a newbie here, this is my first trial, to download a movie, I have bit comet, and I got the torent link. When I ask to start download, everything is ok till about 93% for one and 98.8% for another and that's it both stops, and I cannot go further. When I go check what was downloaded, I can see ome .rar file, but other not recog. Any help will me much appreciated.
Thanks in advance
Walouigi :(
Its possible that the files you are downloading are not currently seeded.
If most of the peers are all stuck at this level, or your not connected to any seeds, then the file cannot finish until someone returns to seed the torrent.
This can be avoided by checking for seeds BEFORE you start the torrent.
If the files is currently seeded, but the download stops, then there is a problem which will require more info to resolve.
you can keep waiting, but if no seeder returns, the download will never finish.
I avoid torrents that don't have seeders, unless I resign myself to the fact that it may never finish, before I start it.
