Error Control
I love bit comet somuch and I think this function should useful for many user
1. I always receive bad packet and inthe peer window they show Error count
many IP send me more than 20 times continuely and this is wasted my bandwidth.
So, I think what if we can control bitcomet V0.71 to temporlary Banned that IP for this task.
then the bandwidth can be use efficiently.
2. can control each task separatly for max peer to connect it
such task A : max 10 peers
, B : max 20 peers
3. more priority : Very High, High, normal, low, Vlow
Thank for all team developer of Bit Comet.
Recieving bad data could be cause by many reasons, one of which could be connection errors on your end.
If you are regularly getting these errors, I suggest you contact your isp, and ask them to check your connection.
This is very easy for them to do, and if you have abnormal packett loss, they will repair it.
It sure wouldn't hurt to have them check
  • 5 weeks later...
To your suggestion 1, the reason you received bad packet is that there was a communication protocal confilict between you and the other peers.
To your suggestion 2,we have an option "Connections to keep per task"(Option—Preferences—Advanced—Connections—Connection to keep per task)to control all tasks peers.
To your suggestion 3,we have three priorities(High,Normal,Low) now. That would be usefull with more priority option.
Thanks a lot.We will consider them.
