GodsLeftNut Posted July 5, 2006 Share Posted July 5, 2006 Hey im fairly new to this. I need some help opening my ISO file. I downloaded Poser 6 + Vue 5 (3d animation) off of bitcomet and i need to know how to open it. It says that i need to burn it...but then what. Im also not sure if its a good file cause it came as one. thanks mike Link to comment Share on other sites More sharing options...
captain_10_iceman Posted July 5, 2006 Share Posted July 5, 2006 I'd say you could try Daemon tools from Daemon tools on their website if u want to try it out b4 burning it. N for burning use Alcohol i dont know exactly the latest version but alcohol wil burn the .iso file good.. Link to comment Share on other sites More sharing options...
GodsLeftNut Posted July 5, 2006 Author Share Posted July 5, 2006 Does it burn more then on cd cause i tried to burn it but i had to put it on a dvd. I also tried Daemon tools...wasnt really sure how to do it. Link to comment Share on other sites More sharing options...
nsevilgenius Posted July 26, 2006 Share Posted July 26, 2006 go here it is crude tut but easy http://forums.bitcomet.com/index.php?showtopic=1210 Link to comment Share on other sites More sharing options...
