0.7 is bugged?
I just downloaded last night and its not downloading any of the torrents from the previous version, or ne other new torrents i have selected.
Does ne1 have ne idea of why this is happening? or having a common problem?
Oh, the borwser is not working either, its like, its not connected to the internet…
check your firewall setting and allow BC in it. Your firewall block all the BC traffic
Please also check that your default download directory is renewed to the same download directory you used in previous BitComet versions.
Firewall is definitely a prone issue, checking your port-forwarding settings are just as important.
It was the firewall…thanks alot.
I had my Norton anti-virus disabled, but i guess its Firewall still applies… anyways, thansk again.
