The maximum number of shared torrent increased to 10,000
But it can not be selected. Other value ( 50,000 or below) is able to select.
Max file path 260 char ? If more, error download. other client normal download
magnet:?xt=urn:btih:c5822c1bf3d083c693e8caf75da98aed47fc22d1&tr=http%3A%2F%2Fbt02.nnm-club.cc%3A2710%2F0020aeb708b69bae425abd42fe506843%2Fannounce&tr=http%3A%2F%2F%5B2001%3A470%3A25%3A482%3A%3A2%5D%3A2710%2F0020aeb708b69bae425abd42fe506843%2Fannounce
Length of file path is a windows restriction and isn’t specifically tied to BC
but qbittorrent normal download all files.
Isn’t qbittorrent a Linux app (I have it on my Linux box and it uses QT)?
Windows 7 / 8 / 10
[https://www.qbittorrent.org/download.php](https://www.qbittorrent.org/download.php)
The length of the file path IS a Windows restriction. qbittorrent uses QT which is a port from Linux and, possibly, doesn’t have the same restrictions. BitComet is a pure Windows app (trust me on that - I’ve never been able to get it to work using WINE or any other app in Linux) and it relies on the MS API to a greater extent than qbittorrent
Check[ this article](https://docs.microsoft.com/en-us/windows/win32/fileio/naming-a-file#maximum-path-length-limitation)
utorrent web normal download
if all files was downloaded other client, BitComet check hash 100% without error
If this was a bug, we would be inundated with dozens of ‘me too’ posts.
There would appear to be a problem on your computer - either a faulty installation of BitComet or a problem with Windows itself. I have been completely unable to reproduce the problem here
However, as I pointed out, the length of the file path is a MICROSOFT limitation. You may have set up your download folder for Bitcomet in such a manner as to exceed thet. Try setting a direct path instead of a subfolder
