I just don’t get how to insert a second CD while installing from ISO files! :blink: Can anyone help me plz?
mount the iso’s on to a virtual cd drive using daemon tools
you can get this from my blog http://my.opera.com/caf4926/blog/show.dml/75377
should be straight forward from here
I prefer using Alcohol 120% to mount and burn disc image files, but daemon tools will also work fine.
You can mount both discs in separate virtual cdrom drives, or change which one is mounted when the program prompts for second disc.
