Hi, Is it possible to add (and/or remove) sites to the Torrent Sites section of the Channel pane under Favourites? Cheers.
We’re not ignoring you, but almost nobody bothers to use the channel pane or the favorites, or the built-in browser at all. It’s pretty crippled, so most of us use our regular web browsers instead.
It is possible but you have to go in and edit the .xml file manually.
Thanks! That answered my question.
