I have it configured as it was installed
Which means that it’s not configured for your particular setup…very bad… you’ll never obtain the best possible performance.
and without limits in Connection/Properties
More than likely you’re choking your own connection with the rest of the peers in your swarm, at the same time that you slow down your surfing speed… Also, you’re probably not offering much stability nor speed to those in your swarm and they’ll regard you as an undesirable peer.
apparently, it downloads when the seeds are connected, it’s matter of waiting
Although it may seem the opposite, the majority of downloads manage to finish dowloading amongst everyone thanks to the peers (and not the seeds), unless the seeds are rationing their uploads and all of the rest of the peers are at the exact same download percentage as yourself.
in the software, not all of them appear, just the ones that are published in BitComet
It’s not surprising, as BitComet is developed in China and it would be impossible that they would be able to include absolutely every single torrent website that exists (and, even less, in numerous languages).
I think that to give so much information is not advisable
If it’s because you fear revealing personal information, I can tell you that it’s neither what we ask for, nor what we are looking for. What we need is to visualize what you already see and know about your PC, your Internet connection and how your BitComet is configured…bear in mind that you have it in front of you…we don’t…we are neither there with you, nor are we mind-readers.
besides, I’ve been using this software since years ago
Some of us have as well… since its beginnings.
