Anyone got this problem?
Example: 10pm i downloading torrents, there is downloading and uploading speed. Next morning, the torrents trying to connect.. so i restart computer and it went back to downloading.. Understand??
something like things Max out, need to restart computer then it can carry on downloading…
Cannot leave it as long as i want because after sometime it trying to connect the torrents… what should i do to allow continuous downloading?
thank you! :smiley:
When your torrents stop working are you still able to browse the web?
Have you capped your upload speed?
How many connections are you allowing Bitcomet to make?
(the combination of “Max connections per task” and “Max simultaneous download tasks” controls this)
I have got that same problem with my wireless network. Every like 5 or 10 hours my internet will just stop working even though i know it is really working and so i just reboot my computer and it works again. But i think it is just my wireless network messing up or something.
Make sure you have the latest firmware for your router
and make sure you have the latest drivers for your wireless card.
Also try lowering the maximum number of connections Bitcomet makes.
(to do this change “Max connections per task” and “Max simultaneous download tasks”)
thank you! :smiley:
Ya i able to browse the web.
Sorry i don’t what you mean? i using modern 512K.
Max connections per task = 79 Max simultaneous download tasks = 10
but i only connect 3 - 5 torrents at a time to download.
Anything i can improve on or any suggestion? Thank you. :lol:
