can anyone tell me how to burn bin and cue files to dvd using nero?
Tell Nero you want to open a disk image, then point it at the .cue file
i can’t find anything to open, just add
One of the two is a smaller instruction file for the burning program. Thats the one you should open in a burning program. You’re going to fine out real quick that nero isn’t good at burning disc images especially duel layer ones.
You should try Imgburn, its free and I know it handles bin & cue. I have a link in my sig for it.
