Hi ive just downloaded a ps2 game once extracted theres two folders a Bin/Cue folder, what do i need to burn this as i have burned using alcohol 120 and the game loads and then doesnt do anything else, can anyone help , thanks.
Alcohol or nero can burn .bin/.cue disc images.
Do you have a “modded” ps2?
if not, then you won’t be able to use downloaded discs.
yes i do, well thats what i have thought but it doesnt work? i used alcohol should i try something else? how would i do it on nero?
I posted a guide for burning .bin/.cue with nero in our guides section.
i have nero startsmart on my computer is this it? if so what do i click on, theres make an audio cd,bootable cd etc etc, thanks.
