Meverick is correct, your limited upload speed is putting you on low priority for receiving download.
Hi all this is my first real post on this forum. I recently hooked up a Linksys WRT54G and “upgraded” to version .83. I was experiencing all kinds of issues w/ BitComet. I came to the forums and found the dd-wrt project through it. I updated the firmware but that didn’t solve my issue. Then found out that it was .83 that was borked. I installed .82 and that fixed my BitComet connection issue. But I was still seeing all kinds of issues w/ the rest of my ability to connect to other sites, i.e. very slow responses. I did a lot of troubleshooting. I adjusted every port and connection setting I could find. Nothing helped. The minute I fired up BitComet I started dropping packets like it was going out of style. After a little more research on dd-wrt wiki I found the solution. To save someone the time and trouble that I went through here is the link that tells you what needs to be done on your WRT54G.
http://www.dd-wrt.com/wiki/index.php/Router_Slowdown
I was trying to follow the advice I found here and limit the # of connections. That info is INCORRECT! You need to set your max # of connections higher on your router and lower your time outs. Yahtzee, problem solved.
Hello this is my first post ,I have upgrad to 0.85 and start to face problems,i don’t have proxy and no router but my speed is too low, i know the rules of seeders ,i use xp.
when i used 0.70 version my speed was ((150-200)mbps.
sooo somebody delp
khalidmomani, I got your PM and sent you a reply.
Also please check your units.
8 bits = 1 Byte
1 Mbps = 1000 Kbps
Bitcomet displays KB/s (aka KBps, aka Kilo Bytes per second)
Your ISP uses Mb/s (aka Mbps, aka Mega bits per second)
Many thanks for the help - i was not aware that BT used bytes for starters ![]()
Anyway, my settings work as follows (in case others with similar ISP speeds to me need help)
i have Max DL = 24 Mbit = 3072 kBytes
i have Max UL = 1 Mbit = 128 kBytes
however, after doing a real world test here: h**p://www.numion.com/YourSpeed3/
i find i have the following instead:
Max DL - 2182 kBytes
Max UL - 99 kBytes
Now - considering i DOUBT very much i can DL from anyone on bittorrent at my maximum DL speed, i have set that at 500kBytes (i dont DL more than 2 films at most) - i have also set UL speed to 80kBytes (99 * 0.8)
Thanks again for great help - it works :blink: hehe
BTW - should i take account of the Max speeds inside my own country (Sweden) ??
TheDodger
i have a quicky question so plz take a look and answer me
im on dsl ppp over ethernet but without local area network (it exist but doesnt work ) so shud i unmark these bt settings like NAT mapping / NAT firewall ?
After you pick the listen port in Bitcomet you have to open that port up in your router.
Go to portforward.com and find your router/modem and they will give you directions on how to do this.
I went to portforward.com and my modem was there but was unable to log in to change the setting in my modem. I get to the page that sets up the modem but cant log in with the default name and password which most know as- admin and password. Any help would be appreciated. When I say modem I mean modem because portforward lists my modem- Westell 6100. It looks like a plain modem to me. I guess its considered Modem/router.
Is there a way to find out what port is already open in the modem to set that one with Bit Comet? Or is that not practical?
Thanks
hey im haveing a problem with bitcomet 1st in the bettem left hand corner of bit comet is a yellow light and saying "blocked: then what looks like a IP..im also haveing never more then 10kb/s download speed, i am also not sure if my settings on bitcomet are right, i have been going around in many fourums looking for help but alot of them are way to confusing for me…
I am useing a speedtouch 585 V6 ADSL modem it is wirless to other computers but i have the internet cable in my PC… thats pritty much evrything i no… if u could message me or something with some help that would be great! thanks, i will also ceep watching this forum incase u post on hear
Hi JCkoolio,
The message you are seeing means that your listen port is either not open properly or that it is being blocked by something (probably one or more firewall/s).
I suggest that you carefully go through the Guides titled “Port Forwading and Static IP” and “Settings Guide” (links in my siggy) and make sure to NOT skip the part about setting up a static IP.
If you’re still having problems or there is something that you’re unsure about, open up a new thread and provide the Essentials (link in my sig), as well apport as much detailed information as possible - too much is preferred to not enough.
hi ive downloaded 0.91 wen i click to open it up i get a error 6030 runtime error wat is that how can i fix it plz
I have 1 question.
How to set BitComet IP Status Light to green? Where I can set this thing?
Please help me!
Its this will help the download speen more faster after set it?
thank you.
I have 1 question.
http://forums.bitcomet.com/index.php?showtopic=3880
It should, if all of the other settings to adjust your client have been configured properly.
Okei here is a damn annoying problem. i have school internet(yeeah that bad ugly thing) 20-40 mbit/s
im behind a web proxy(well not a big problem) but also behind NAT gateway(sharing 1 ip with many other people in my lan). None of those nat settings work. only open ports iv noticed are 80(http) and 22(ssh).
Tho there is one p2p program that works without problems, bearshare(music only), dunno how its made possible.
So any advice? Admin wont open or foward anything. Any way using 80/22? And i dont wanna use any tunneling, cuz they charge too much per month and speed aint actually that good.
I cant login (grey) and network status is also grey, only DHT is green.
Lifestream, I suggest you set “Nat Traversal” to always. This should get you “some” remote connections. It’s not as good as having an open listening port, but might be your only option.
There’s no reason you can’t use either port, provided you yourself aren’t actually running a server that also uses that port. It’s for incoming traffic. If you don’t HAVE a webserver, then you won’t have any incoming traffic, at least not that you want, on port 80, so you can use it for whatever else you want. Likewise for port 22.
Use of particular ports for particular services is just a convention, not a rule, and it’s for the benefit of other people. If I tell you that you should try my web site, your browser will assume, as it should, that my web server will be found on port 80 unless I have specifically said otherwise. If I don’t have a web server, then I can use 80 for anything I want.
no web server running . Also nat traversal is set to always, but any torrent im testing is still in connecting status.
port 80 and 22 doesent seem to work tho any online port scan reports it open.
It sounds to me like your network Admin is blocking Bittorrent traffic. Have you tried setting protocol encryption to “always” also?
If that doesn’t help, you might have to find a way to use a proxy, or use a different type of downloading on campus.
yeah, doesent work, admin is a bit too smart, only way is tunneling (proxy is to slow if i ever find a good one).
Umm, be aware that colleges and such often have a policy forbidding P2P on their networks. It’s one thing to outsmart the admin, if you can, but if you violate the policy they kick your a** out, or cancel your network account, or deactivate the network jack in your dorm room which will make you dearly beloved of your roommate. So know what you’re risking.
