Settings Guide for Bit Comet is located in “Guides and How to” section…
Settings Guide <— Click here
Hi. I’m a newbie at this torrent/forum. so i apologise before i offend anyone on this post.
I’ve read the Settings Guide and i think im fairly competent with computers but where the guide refers to
listening ports i’ve changed the port numerous times and i cant get seem to get any peers on “Remote”
inititian. I already have a sadly slow broadband connection and the current torrent i’m downloading is going sooo slowly, i’ve wanted to cry. At the same time i’ve downloaded other torrents fairly well for my circumstances.
if you can help me in any way i will greatly appreciate it.
ChRoN
After you pick the listen port in Bitcomet you have to open that port up in your router.
Go to portforward.com and find your router/modem and they will give you directions on how to do this.
I tried that but my router is not on their list.
Can you answer these questions? Since, it is common for some routers not to be listed at portforward.
Can you access your router page? (i.e. By default you can access your router’s page by 192.168.2.1)
If not consult your Router’s manual. Also, double-check whether you really have a Router (sometimes if it is not listed at portforward.com, then you may have a modem).
Can you see a section called Virtual Servers? OR Port Channels? It may be listed under Firewall.
Hi .. being a newbie to BitComet ( and Torrent downloading in general), I’ve been slowly learning the nomenclature .. however, I cannot find in the BitComet FAQ , Setting Guide, or HELP sections an explanation for some things .. for example, while looking at the “peer” info while downloading, there are a number of columns , some self explanatory ( download and upload rates, etc.) but some that aren’t clear ( e.g.: % ( % of what?), status (__d0_0 ?), etc.
Can you point me to a page or document that explains in detail what these things mean?
i get this message how can i fix it? i’m a newbie
Unable to find the bottom of the page
Search pages you are likely to have been deleted, renamed or not allowed to use.
Please try the following operations :
Ensure that the browser address of the web site address shown in column format and the correct spelling.
If the link and arrived at the website by clicking on the words, please contact the site manager, informing them of the link format is not correct.
Shoot Retreat Button to try another link.
HTTP error 404-paper catalog or not found.
Internet Information Service (IIS)
Information technology (for technical support staff)
To Microsoft product support services Including search and “HTTP” and “404” title.
Opening up a “help IIS” (in IIS Manager (inetmgr) visit), and then search for the title “website set up,” “conventional management tasks,” and “erroneous information from the definition of” theme.
Hi,
Please post questions in a new topic. This post is only to help people find the settings guide.
However, you are following a dead link, possible to a web site that no longer exsists.
Just find a different source to get your torrent/s.
Hi: I’ve gone through the FAQ etc… and can’t seem to get my download above 60KB for any length of time. My line test indicates 320KB+ down and 82KB up. I get both local and remote initiations. I am currently trying to download a file with masses of seeders and peers and I am getting around 40KB down.
Up is limited to 20KB
Wireless Router is Linksys WRT54G
Fully updated Windows XP w/ Windows firewall off.
McAfee with Firewall on and BitComet has full access.
Listen port in 50000’s
Any suggestions would be hugely appreciated.
Thanks,
J
i have a question
i checked at “Auto start Bitcomet when logins Window”
but when my Window starts up, Bitcomet doesn’t start
sorry for my bad english
i have a question
I’m not sure what version you are using, so can’t really comment, but you could make a bit comet shortcut icon in your startup folder.
any programs in that folder will start, even if the program itself isn’t set to start.
I’m having problems getting an account name to login to bitcomet. What do I do? ![]()
You do not need to login to Bitcomet to download stuff.
This is a new feature that is being tested in the new versions.
You can either ignore it or go back to version 0.70 for now.
Get old versions Here
Hi, first post here, hopefully someone can help =/. I have the same problem as someone before. I’ve followed the port forwarding steps, created a listening port and configured my router to use that as a “virtual server” etc. But still I am stuck with “local” initiations and in return, very bad transfer rates, but only for torrent programs. My internet runs quite fast and so do regular downloads (and even dl’s on limewire). Any other threads I should look at? what may be the problem??
Thanks. B)
Hi,
Go to “canyouseeme.org” and test your listening port. If you get anything other then “open” as a result, you either have a firewall (or other security program) blocking your port, or your router isn’t setup right.
Also, be sure you have set a static IP address on all computers sharing that router.
Hi,
Ah, my families pc is connected to the router… that may be the culprit. I’ll do that later today and let you know if it helps
Thanks
if your other computer already has the IP address you set as static, there will be a conflict, which will likely result in your using a different IP.
After you are done, check your IP against your routers port settings to be sure its still the same.
The other pc didnt have a static ip set so I did that. But still no go. I checked if my listening port was being seen from that site you gave me and it was saying the connection was timeing out, or it’s being refused(gah >.<). I followed the static IP tutorial and set both pcs up with one, and when it came to the port forwarding thing where it asks you for your static IP I imput the IP that I placed under “IP Address”, I assumed that was the “static” IP given to my pc.
Hm.. oops. As im typing this I checked my virtual server ip and the “private IP” was set to the router default instead of my static IP (they are very similar). So I feel like an idiot :P. I checked Bitcomet and my downloads now are showing a few remote initiatives(but im still not downloading very fast <10 KB, guess I havent found any viable sources?). canyouseeme.org is also seeing my port saying that my isp is not blocking.
SO i guess everythings going as it should? If so, thanks for your help ![]()
hello masters of BitComet,
i have a very easy or hard question to ask u in ur expertise
if i change the preferences in the 0.80 version of BitComet
can those changes be done in the 0.70 version with the smae results or do they only
work on the 0.80 version?
u see it’s because i have a dsl connection but the download speed
is only 1-2kb/s on the smallest file which in my case is 6mb.
or is there a way to speed up my down. speed?
Your upload speed should be limited to 80% of your line speed,for yours about 65 kb/s
