Bitcomet 0.70
Hi
Anyone encoutered this problem that if you click on any torrent site, the address bar just shows this "http://www.clickaudit.com/goto/?36890" and doesn’t respond anymore…
I tried re-installing and still the same.
:frowning:
This sounds like you might have a browser hijacker present (spyware/malware).
Some of these are quite hard to remove. Here are the programs I use (I use all of them, one at a time to clean an infected computer)
1st, run a good antivirus with latest updates. My favorites are Kaspersky and McAfee.
Then I run Spybot search and destroy, then Ad Aware (be careful for sound alikes). Both of these are free.
I have found that xoft anti spy is the best at removing hijacked browers. This one isn’t free, but is availble on most major torrent sites.
HiJack this, is also a good one, but not for a novice.
Thanks for your reply! I will try what you suggested.
By the way, why is i that this spyware/malware only affects my bitcomet but not internet explorer?
Does it specifically target only bittorrent programs?
