I tried to do this once myself using Azureus and Azbot guides
It just made my downloads slower!!! AND who would know their
site’s capalities better! Here is the requested info you ask for before I post
Bitcomet version1.29 ps dxdiag in attach.
Cox Cable Provided WiFi 70% strength and link full 54Mbs wep
password protected
While I don’t have access to the apt complex router I do have port forwarding enabled and light on indicator is green (your statics
confirm that) listen port opened
I use Window Firewall XP Pro sp3 and put my IEEE 802.11,your
web site and my pc games on the excemption list
I use no A-v unless I get a virus I can,t fix say in registry
or system restore even then I find OS restoration preferable
Here’s a little known hint, the best deterant to infection is pure speed, get in and get out of site as fast as possible thus out
racing the hackers software. This requires fast downloads…I once
configured a 802.11g to download @ 150 Mbs
Speedtest results in Kilo BYTEs
After four tests Down UP
557. 313.
300. 124.
246. 305.
323. 105.
Maybe its the nature of WiFi to have such varied results
I can tell you when it comes to Bit comet my average
upload speed LATELY is 18. to 22. Kbs but at time it has even risen higher than DL speed (aver.400.Kbs) My email address
ricofogg@yahoo.com if anyone would like to reply outside of forum
(I never check the forumS @ reg. intervals) Please give me
suggested #s’ for the max up rate ,global limits , task limits,ect.
Port forw. already OK Listen Port config. correctly
Thank You
There are two related questions if you know the answer
A. Is any download acellerator progs (i.e. DAP93 or IDM )
compatible w/ BitComet?
B Do you have written instructions on how to donate /upload
Full games and software to this site…you folks are awesome
time to start giving back.
Again reply preferably to my yahoo inbox. I can give much advice as to WiFI anntennas, speed , configuration
Thanks Again
DxDiag.txt (44.2 KB)
