BITCOMET ERROR 10060
Buna seara,
La conectarea bitcometului la adresa tracker-ului imi da eroarea 10060 A connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host failed to respond.
utilizez de 2 ani clientul bitcomet pt.acest tracker si nu mi-a dat pana acum aceasta eroare.
multumesc anticipat.PRTSCN-BITCOMET.rar
Good evening,
When BitComet is connecting, I see the " 10060 A connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host failed to respond" error next to the tracker address.
I’m using BitComet for 2 years now for this tracker and this is the first time I see the error.
Thanks in advance.
PRTSCN-BITCOMET.rar (105 KB)
This is not a BitComet error. All of the codes like this are WinSock errors.
10060 is a simple timeout. While you may not have seen it before, it is an extremely common error, and indicates that the contacted party did not reply within the allowed period.
Aceasta nu e o eroare de la BitComet. Toate codurile de eroare ca acesta vin de la WinSock.
10060 este o simpla eroare ca s-a scurs timpul de asteptare. Desi nu ai mai vazut-o pana acum, este o eroare foarte des intalnita, si indica faptul ca partea contactata (trackerul) nu a raspuns la timp in prerioada acceptata.
