BitComet is constantly freezing/crashing
I installed latest version of BitComet on a clean installation of Windows 10 (x64), but the application is freezing and then crashing constantly. I open it and resume torrents downloading, but after a minute or so it stops responding and I have to shut it. However, it crashes so badly that I can’t even kill the process on Task Manager immediately, I have to wait a few instants before the process is terminated. When I start BitComet, I have to hash check every torrent due to the crashes, which is really annoying. Why is BitComet freezing so constantly? Will reinstalling BitComet fix the freezing/crashing? Thanks in advance.
I think this happens because of HardDrive overload. We can fix that.
Please tell us, how much RAM do you have?
Thanks for the reply. I have 6 GB of RAM (4+2 GB DDR3L @1600 MHz), and it usually has half free.
Go to ***Tools > Options > Disk Cache ***and change the default settings to these ones:
• Minimal disc cache size: 50
• Maximal disc cache size: 1024
• Shrink disc cache if free physical memory lower than: 500
• Cache size for HTTP: 2048
Your BitComet was freezing probably because you HDD was overworked. We’ll fix this issue by increasing the amount of memory used for cache.
