Bitcomet log in problem
I can’t log in bitcomet since this morning. Is there something wrong with the database or server?
It hiccups now and again - just keep retrying (the auto-retry doesn’t always work)
i can’t connect to my account, it’s always saying server connection ( connection au serveur ) in french and it’s like that for like 9 month and i always keep retrying and he never connect to the server
Try a clean install (use the demo version of Revo uninstaller) after saving the Bitcomet files in appdata) and make surew that the windows firewall isn’t blocking the app
it’s a new installation of bitcomet with a new installation of windows too and i did deactivate the firewall, noting, still don’t want to connect to the server
check that your router is set to tcp/udp ports that match the computer (it’s best to use a fixed IP number for this)
