when this occurs, and you can’t reach anywhere, does shutting BitComet down fix the problem? Can you now browse to web sites &c., or must you do something else (like reboot) before you can use the internet again?
The usual cause of this is failing to configure BitComet (or, really, any bittorrent client) correctly. Please refer to our settings guide in the Guides forum, and step through your configuration. Pay especial attention to testing and then setting your global maximum upload speed correctly, which is often the heart of this problem.
