BitComet SDK
Hello, I’m trying to build an application which uses Bitcomet and I can’t find any documentation nor examples to how to use BitCometAgentLib and BitCometBHOLib. I need them in order add a new file into Bitcomet and to make Bitcomet to begin the download.
I will be very thankful for any kind of help or guidance for this matter.
My problem, at this point, is to add a torrent file to Bitcomet because of the confirmation part (I want to automate the confirmation).
Thanks
Alex
Well, I don’t think it would be a good idea to skip the confirmation part. Still I’ll convey your suggestion to our technical staff. Thank you for your support!
Hi, thanks for the response.
What I mean is that I need the ability to add a torrent file to bit comet automatically by using BitCometAgent or something like this.
Alex
