Buna prieteni. Am o problema foarte sacaitoare cu BitComet. Cam de 4-5 ori pe zi mi se restarteaza. Dupa cateva ore (uneori cand viteza de download este mare, dar nu intotdeuna) incep sa se opreasaca unele sarcini (cu X). Deja cand vad 2-3-5 torrente cu x, ii dau eu restart, daca nu o fac oricum se restarteaza singur dupa ceva timp. Folosesc de multi ani bitcomet, aceasta problema a inceput prin primavara. Internet ppoe de la rds, XP 32, BitComet 1.22 (am incercat si cu 1.20, 1.21 si 1.23) Port deschis, viteza f buna, nod32, fara firewall.
A mai patit cineva, aveti vreo idee???
Hi friends. I have a very annoying problem with BitComet. It restarts about 4-5 times a day. A few tasks start stopping (with the X) after a few hours (sometimes when the download speed is very high, but not always). I restart it myself when I see 2-3-5 tasks with the X, it would restart all by itself after a while anyway if I don’t do it. I’m using BitComet since a lot of years ago, this problem started since about last spring. My internet connection is PPPOE and my ISP is RDS, my operating system is windows xp 32bit, BitComet 1.22 ( I tried 1.20, 1.21, 1.23 too) Open listen port, mey speeds are very good, NOD32, no firewall.
Is anyone else encountering this problem, do you have any ideas?
