downloaded bitcomet 1.58 for windows 8 and I try to send torrents to it and it loads but nothing on bit comet is running. ive had bit co0met on windows 7 before nand never had an issue
Check thatyour firewall isn’t blocking it. Do you have two green ‘lioghts’ at the bottom right?
