Hello guys!
My BitComet proccess is using 1042 MiB of my RAM in my Task Manager.
Is this normal?
Thanks
Hello guys!
Is this normal?
Thanks
Memory usage can increase if there are a lot of files being transferred (up or down). I’ve 5 torrents running and memory usage is almost 500 MB. You also have 7 instances running (I have 2)
Note that 'memory' doesn't just refer to RAM - it also takes in pagefile
Have you solved the problem?
/monthly_2021_11/image.png.c396060c7bdd7015c2be1a120a547288.png" class=“ipsAttachLink ipsAttachLink_image”>
There actually isn’t a problem - background running apps eat up memory
