Welcome to download the beta version and try out the new features. Please provide feedback, thanks.
v1.66 Beta8 [20200411]
GUI Improve: support add batch-download by drag and drop multiple URL links to floating window or main window
GUI Improve: support add batch-download by clipboard monitor
GUI Improve: new advanced option: bittorrent.hash_check_for_ltseed
GUI Improve: add memory usage details about process heap size and disk write buffer size
GUI Bugfix: UI lag when select all by Ctrl+A in torrent list
Core Improve: reduce memory usage when downloading metadata for DHT torrent list
Core Bugfix: the global option "allocation disk space before download" works even when disabled
Core Bugfix: empty files should not be created when performs hash-check
https://download.bitcomet.com/beta/BitCometBeta_20200411_setup.exe 1
[https://download.bitcomet.com/beta/BitCometBeta_20200411.zip](https://download.bitcomet.com/beta/BitCometBeta_20200408.zip)
v1.66 Beta7 [20200408]
GUI Improve: add Feed Name in RSS torrent list
GUI Improve: display number of piece in torrent maker dialog
GUI Improve: display metadata downloading info in Statistics pane
GUI Improve: do not display listen port of peer if unknown for BT peers
GUI Improve: "Preview Download Mode" renamed to "Sequential Download Mode" in context menu of BT task
Core Bugfix: "Sequential Download Mode" does not work if "Optimize download strategy for preview" disabled in Option dialog
Core Bugfix: improve memory allocation, decrease memory fragmentation for UDP buffer
v1.66 Beta6 [20200404]
GUI Improve: new advanced option: system.compact_memory_interval
GUI Improve: display configuration file folder in Global Log pane
GUI Improve: display Long-Term Seeding status in Statistics Pane
GUI Improve: "Hide torrent without metadata" setting renamed to "Only show torrents with metadata" in DHT torrents list
GUI Bugfix: "Only show torrents with metadata" setting not applied to new received DHT torrents
GUI Bugfix: incorrect configuration file folder used in certain case
Core Improve: improve Preview download mode for BT task
v1.66 Beta5 [20200402]
GUI Improve: new advanced option: bittorrent.max_connections_per_ltseed
GUI Bugfix: task summary panel text alignment
GUI Bugfix: level progress display error when progress is 0% in the lower left corner
Core Bugfix: connection error retry issue when download from long-term seed
Core Bugfix: DHT Tracker unstable causes program crash
v1.66 Beta4 [20200331]
GUI Improve: add Compact Database command in settings menu of torrent list
GUI Bugfix: the number of torrents in the left channel list is not refreshed in time
Core Improve: DHT Tracker use worker thread to reduce the UI lag
v1.66 Beta3 [20200330]
GUI Improve: improve icons in toolbar and download list for HiDPI display
GUI Improve: add settings button in toolbar of torrent list
GUI Improve: new option for DHT torrents: Hide torrents without metadata
GUI Improve: new advanced option: bittorrent.dht_torrent_refresh_interval, 5 sec as default to decrease disk activity time
GUI Improve: add copy command to context menu of settings list in advanced option page
GUI Bugfix: sort bug for first column of Torrent History list
Core Improve: improve memory allocation, decrease memory usage for UDP buffer and log buffer
Core Improve: optimize UDP packet sending efficiency,default value of network.max_udp_pkt_per_sec changed to 1000 from 500
Core Improve: avoid program crash caused by IE component damage
Core Bugfix: fix speed limit deviation
v1.66 Beta2 [20200322]
GUI Improve: new option in Proxy setting page: DNS query using proxy server
GUI Improve: improve HiDPI support for Batch download dialog
GUI Improve: show pending DNS number in Statistics pane
Core Improve: support IPv6 connection through SOCKS5 proxy server
Core Improve: support UTF8 BOM when improve URL list from text file in Batch download dialog
Core Improve: support extract URL links containing Chinese characters from html page segment dropped to BitComet from web page
v1.66 Beta1 [20200319]
GUI Improve: new settings in advanced option page to select IP address to bind to when initiate a connection
Core Improve: support initiate a connection using preferred network adapter if multiple network adapters exist in system
