BitCometBeta 20060722 Released
BitCometBeta can be found at this page:
http://www.bitcomet.com/doc/download-beta.htm
BitCometBeta ChangeLog
20060722
Add option to auto stop after task finished
Fix UDP Tracker can not be connected
Fix HTTP Tracker redirect do not work
Beta version can only run on Windows 2000/XP
20060719
Add preview
Improve upload strategy.
Install to BitComet directory, can work with release version.
20060716
Fix the crash when click OK in the Setting Dialog.
20060713
Rewrite core code. Some functions are disabled temporarily.
no more protocol encryption?
hello, i want to be a meber of the biitcomet plz tell me how
Please specify exactly what you mean by this message.
Are you saying you are a programmer and want to help in developing bit comet?
If you want to be a member of the forum, you already are a member.
ps. this is also not the correct place to post this question
