Blocked TCP port
Hi, have tried everything to unblock the TCP listening port which has only happened since I added a D-Link router to my system. Have been thru all instructions, tried everything but no luck. Any more suggestions?
for someone that has “read all instructions”, you seemed to have missed the one about what info to include when making a support request. You also posted this question in a section for asking questions about torrents, not about bitcomet.
However, to get you started in the right direction, it’s portforwarding you need to setup in your router. Portforward.com has free guides to walk you through the process.
If you still need help, then read the instructions on how to prepare a support request and post it in the right section.
topic closed
