Bugs MPCSTAR 5.2
- Bug view video fraps decode;
**- Bug view video Video: **
MPEG4 Video (H264) 1024x768 29,97fps 4893Kbps [Output 0]
Audio: AAC 0Hz 0ch [Output 1]
((Start play video in 5 seconds!))
Probably bugs codecs!!
Please work this!
If someone has the same problem comment
Thanks :slight_smile:
We are aware that some users are having issues with some mpeg4 video. Our forum staff’s testing seems to point to a conflict with other codecs installed on the system.
We have reported this to development so it will be addressed.
If you have installed any codec packs such as K-lite, uninstalling them should fix the problem. Reports have shown that CCCP codec pack doesn’t conflict with version 5.2 if you want an alternate codec pack to use, or of course you can revert back to a prior version of mpcstar. I believe 4.9 should play your mpeg4 video.
