You’re going about this the wrong way. You need to test your connection’s speed (preferably several times) on a test site such as speedtest.net in order to get a more realistic view of the speeds you can achieve.
Then you need to transform the upload speed in bytes (dividing it by 8 will give you a pretty good estimate) and limit the global upload of BitComet to only 80% of that. Have you done this already or not?
Then follow the procedure kluelos told you to, in order to see how many tasks you can successfully run. Once you found that number (whatever it may be) you may want to subtract from it 1 or 2 just to be on the safe side.
You didn’t give him any response as to the results of this procedure, just reported back that you were running 41 tasks instead of 215. That tells us nothing; we can’t say if those are too many or not, because we’re not in front of your computer.
You need to acknowledge that the upload speed BitComet can make use of (the 80% of your connection’s capability) is a finite thing. When you use multiple tasks your upload bandwidth gets divided among them.
I’m not sure what you mean by the other tasks which are “accumulating” but if you’re referring to completed tasks which are seeding, then you need to know that they’re using a part of your upload capability too.
The number of both downloading and seeding tasks needs to be limited to a finite number that will fit to your upload capacity. You can do that either manually (by watching your Task List and making sure that the number of active tasks - both downloading and seeding - doesn’t exceed the max number of tasks which you’ve determined that your connection can support (by the method which kluelos explained to you) or you can make BitComet enforce that limit automatically, by using the options to limit the number of downloading and seeding tasks, on the Options–>Task page.
In the latter case, if you start a bigger number of tasks than the set limit, the rest of them will go into a downloading or respectively an uploading queue (depending whether they’re downloading or seeding) and will wait their turn to become active.
This is the right way to achieve best speeds out of your client and it’s a fine tuning process that is intimately related to the upload capacity of your connection.
Whether you’re doing it right or not, we can’t say, since we have too little data.
If you still can’t figure it out by your own, then you’ll have to post screenshots of your Task List, of the Statistics tab, Peers tab and of the Options–>Connection and Options–>Task pages.
Te estás equivocando en cuanto a la manera de hacer esto. Necesitas comprobar la velocidad de la conexión (preferiblemente varias veces) en
algún sitio como speedtest.net , para obtener una idea más realista de las velocidades que puedes obtener.
Entonces, necesitas convertir la velocidad de subida a bytes (dividiéndola por 8, te dará una aproximación bastante fiable) y limitando la máxima subida global de BitComet a sólo un 80% de eso. ¿Has hecho esto ya, o no?
Después, sigue el procedimiento que kluelos te ha indicado, para ver cuántas tareas puedes activar exitosamente. Una vez encuentres ese número (sea cual sea), puede que quieras restarle 1 o 2, sólo para estar seguro.
No le has dado ninguna respuesta, en cuanto a los resultados de este procedimiento, sólo has dicho que tenías activas 41 tareas en vez de 215. Esto no nos dice nada: no podemos indicar si eso son demasiadas o no, porque nosotros no estamos delante de tu PC.
Necesitas reconocer que la velocidad de subida que BitComet puede utilizar (el 80% de la capacidad de tu conexión) es una cosa finita/limitada. Cuando tienes múltiples tareas, tu ancho de banda se divide/reparte entre ellas.
No estoy seguro a lo que te refieres al decir que las "demás tareas se están “acumulando” " pero, si te refieres a tareas completadas que están actuando como semillas, entonces debes de comprender que están usando una parte de la capacidad de tu subida, también.
El número de tareas de descarga como las de subida necesitan estar limitadas a un número finito, que encaje con tu capacidad de subida. Puedes hacer eso manualmente (mientras observas tu Lista de Tareas y asegurándote de que la cantidad de tareas activas - bien de descarga como las de subida - no sobrepasa el número de tareas máximas que has determinado que puede aguantar tu conexión (usando el método que kluelos te explicó), o puedes forzar a BitComet a que se ocupe de dicho límite de forma automática, usando las opciones para limitar el número de tareas de descarga y subida, en la página Opciones–> Tarea.
En el caso último, si empiezas con un número de tareas superior al del límite designado, las demás se situarán en una cola de descarga o subida (respectivamente - dependiendo de si éstas están descargando o subiendo) donde esperarán su turno para activarse.
Ésta es la forma correcta de lograr las mejores velocidades con tu cliente y, es un proceso de ‘afinar’ que está íntimamente relacionado con la capacidad de subida de tu conexión.
Si lo estás haciendo de forma correcta o no, no lo podemos determinar, ya que carecemos de datos.
Si pese a todo esto, todavía no lo puedes lograr por ti solo, entonces tendrás que incluir capturas de pantalla de tu Lista de Tareas, la pestaña de Estadísticas, pestaña de Pares y las páginas de Opciones–>Conexiones y la de Opciones–> Tareas.
