Cant connect to tracker
Hi
Would appreciate any help,
I am on a company LAN and was using Bitcomet fine on a win2000 PC. I now have a new PC with XP and cannot connect, no DHT connected, cannot connect to tracker (10060).
I have turned off windows firewall.
The only difference i can see between the 2 PCs is that the win2000 PC has both a LAN & WAN IP, winxp PC only has LAN IP.
As another PC works in the same office im guessing its not router/ports?
Any ideas?
have you tried more then this one torrent?
from what you are saying, it sounds like a problem with the torrent, or a firewall issue.
Have you setup port forwarding in your router?
at the following site, towards the bottom of the page is a nat test, you can enter your port number and test if its open. If this tests good, then your torrents should work, so long as no firewall is set to block bit comet.
http://infinite-source.de/az/az-calc.html
