A few days ago I moved places, and in doing so, I updated the ADSL modem I get from my provider. Before the move, I could download anything just fine… I moved, changed nothing on my computer’s settings, and now everything I try to download just sits on the “>> Connecting” status and never actually connects to anyone… the only differences are the modem I use, which is a Web Caster V110 and a different IP address… any ideas??
That modem is apparently also a router, so you will need to portforward it to get Bitcomet working properly
There is a guide for doing this in the Guides and HOWTO section
Also you should consult the manual for that modem/router to find the username/password(if you have it)
You’re right about that, but the modem I have isn’t on the list at portforward.com… so when I get to the “Next, Head to http://www.portforward.com/routers.htm and locate your Router model + brand. Then, locate BitComet, and follow the instructions onscreen.” part of the guide, I don’t know what instructions to follow…
I’m in Japan and therefore using a modem by a Japanese company… It’s a Webcaster V110 made/distributed by NTT… I can’t read enough Japanese to know what to look for, but my wife could probably help me if I need anything from the manual…
Do you know a similar modem model on that portforward.com list I could use or anything else I could do?
No i didnt see any other routers of that brand
maybe one of these two guides will help you
http://forums.bitcomet.com/index.php?showtopic=3880
or
http://www.p2pforums.com/viewtopic.php?p=99434#99434
You may need to read the manual though to figure out the username and password to log into the router
