i previously install the version bitcomet0.77. after i instll it, i try open and there have n rror msg indicate "cant listen to port " ( is some number which i forgotten). after that i uninstall it nd install bit comt version 0.66. turn out that the sam error pop up also..may i know what is wrong with my computer? or is it anything to do with the settings?
What I read from your very brief post could indicate that another application is using that specific port.
Use ports > 40000
For a more thorough answer please report what connection, OS, modem, router, etc.
Petch01
If you are indeed using a router, then you will need to forward your listening port, and set a static IP address in windows.
Portforward.com has guides for this.
