upgraded from CometBird 5.0 to 9.0, upon downloading Comet changes screen resolutions to minimal standards, manually change resolution works, but upon screen change comet goes back to lower resolution.
Cometbird cannot change your screen resolution. I suspect you are trying to describe something else and not using the proper terms. If you really do believe your resolution is changing, then please tell us what your settings are before and after running cometbird. Seeing screenshots of your graphic card settings too would be nice. Without this, or some detailed explanation, we cannot take your report serious enough to even try to duplicate it, but if you do your best to describe the problem so we can understand what you’re seeing, then we’ll try to confirm it and submit it to development if successful.
Perhaps the best thing to do is post some screenshots of what you’re looking at and what you feel is wrong about it… seeing the problem will explain more then many words ever could.
Please make sure to post in the correct forum.
topic moved
