Cyrilic subtitles encoding problem
Hello,
I’m a new user to the forum, but I want to suggest some features for the player.
I’m Bulgarian and my subtitles are Cyrilic. The problem is that I didn’t saw an option for encoding the subs in Cyrilic.
I hope in the next release there will be also Cyrilic support and I can help translating the player to Bulgarian - for free of course!
Keep the good work and have a nice day!
The player doesn’t create the subtitles, it merely shows them. Someone else must create subtitles for any given movie, and encode them into a form that can then be played along with the movie. If a cyrillic subtitle stream exists, then MPCStar can display it. If such a stream does not exist, nothing you can do to MPCStar would change that.
Previously,when I was on Windows 7 starter, I had mpcstar player and he played all cyrilic subtitles right and after I installed Windows 7 professional and again installed the movie player all the cyrilic subtitles turned into this “áéíóáóíéá”.Please help.
You might need to install the proper language support pack in windows.
http://windows.microsoft.com/en-us/windows/language-packs#lptabs=win7
