My statuses on seeds keep reading this, and ones listed as that dont upload at all…any way to fix it.
Heres a screenshot of my window, seeing as my explanation sucks
also, is error 0 normal?
Anything abnormal? Could you please say it more clearly?
if “0” is under the error colum then that means there are no errors.
I don’t really understand what the problem is. Are you trying to upload, download, or what?
When you connect to peers within a torrent download. It does not guarantee that every peer you see in the Peer tab will upload to you.
In fact, I don’t think any torrent client allows to set which peer will upload to you, and which one won’t.
