Hi,
It seem my d/l is always at >3kb/s and tthis has been going on for many months and my friend was saying this is abnormal.
I did a speed test on one of the website and my spped is:
119.7 kilobits per second
Communications 119.7 kilobits per second
Storage 14.6 kilobytes per second
1MB file download 1.2 minutes
Subjective rating Mediocre
My BC settings are:
Global Max Download Rate: No limit
Global Max Upload Rate: 22
Max Simultaneous Download Tasks: 5
Listen Port: 49999
Minimum Upload Rate Per seeding task: 10kb/s
Advanced/Connection
All box uncheck
Maximum Connections per task: 250
Connections to keep per task: 100
Global maximum upload slots: Auto
Global minimum upload slots: Auto
Socket Send Buffer Size: Auto
Socket start Interval (ms): 300
Max half-tcp connections: 5
Use NAT Traversal via UDP: Enable
Advanced/IP Rules
Only Check - Enable reporting LAN IP to Tracker
Max Sessions per IP for downloading task: 50
Max Sessions per IP for uploading task: 10
I’m using BC 0.58 version.
I also realise that under peer all the seeds are LOCAL.
Pls advice what could be the possoble reason for the slow d/l.
Thanks in advance
