Despre piece parts
Salutare tuturor!
Folosesc bitcomet 1.16
problema mea e urmatoarea: de foarte putin timp mi-a “murit” windows-ul; l-am reinstalat dupa care cand sa imi reiau upload-ul unor task-uri in bitcomet…ichiu. nu mai erau.
Vreau sa stiu daca pot si daca da, cum pot sa creez task nou, dar acelasi folosid acele piece parts care imi apar in folderul in care am dat jos torrent-ul.
stiti vreo metoda? ca nu prea am cum sa ma apuc iar sa dau jos inca o data aceiasi torrenti pe care i-am avut inainte sa-mi cedeze wuindows-ul.
Multumesc!
Hi everybody!
I use BitComet 1.16
My problem is that: a short time ago my windows “died”; I reinstalled it, and after that when I tried to resume uploading some tasks in bitcomet… they weren’t there anymore.
I want to know if I can and if I can, how to create a new task using the same files that I see in the folder where I had previously downloaded the torrent.
do you know any method? because I can’t really download again the same torrents that I had before my windows broke.
Thanks!
Salut!
Da, poti.
Descarca din nou torrentele selectand exact acelasi folder de descarcare (daca sarcina creeaza un nou folder atunci trebuie sa alegi folderul care contine acel folder) si dai click pe Download Now. Un chenar de avertizare iti va confirma ca ai ales locatia corecta si-ti va cere sa faci o verificare a hashului inainte de a porni sasrcina. Daca dupa ce se termina verificarea hashului torrentului progresul sarcinii e tot 0% inseamna ca ai gresit torrentul sau folderul de destinatie.
Yes, you can.
Download the torrents again selecting exactly the same download folder (if the task creates a new folder select the folder that contains that folder) and choose Download Now. A warning box will appear confirming that you chose the right download folder and it will ask you to do a hash check before starting the task. If after the hash check finishes the task completion percentage is 0% it means that you either downloaded the wrong torrent or you chose the wrong folder.
Thanks! That was really helpful :smiley:
Multumesc! Asta m-a ajutat cu adevarat
Cu placere! :slight_smile:
Pe viitor, te rog scrie in romana in aceasta sectiune a forumului. De traducerea in engleza ma ocup eu. :wink:
With pleasure!
In the future, please write in romanian on this section of the forum. I’ll take care of the translation.
