DHT network
I have enabled DHT , but it doesn’t work (it is not green) .Firewall is enabled for bitcomet (permit all in NIS) .
How make it working?I don’t understand , i have never had this before.
thanks
The DHT network uses UDP packets, so your firewall rule must be set up to permit UDP as well as TCP. Some firewalls allow you to specify “both”. If yours does not, you’ll need two separate rules, one for TCP, one for UDP.
You do not need DHT in order to download. It’s nice to have, but by no means necessary, and many torrents have it disabled anyway.
