Hey fellas
I can connect to peers but not to trackers or DHT because of my evil ISP. There's an easy way around and it's to temporarily use a VPN to get the torrent started.
(I'm not using the VPN for privacy mind you. Privacy is not important where I live.)
Instead of having to connect/disconnect a vpn to get torrents to start, I was thinking of perhaps filtering solely the DHT traffic onto my vpn automatically. I could try to do that on my Openwrt router using appropriate packages.
I do need to know what the DHT traffic is like. Can I isolate it somehow? If you guys had an option to connect to DHT and UDP trackers over a proxy then that would be fantastic. I don't see that option though.
Http trackers don't work for my torrents I'm afraid. So the current proxy options are useless.
