download problem
My bitcomet client used to download before. but it has stoped now. It says the DHT is not connected
and i don’t know what might be the problem. I’m accessing the internet through a network.
as it has been said a million times, DHT is not neccessary for the torrents to download
If DHT is not necessary why may be the reason for the bitcomet to stop downloading. If u have any suggestion …
Can you tell us if your bit comet is not working on all torrents, or only some?
Only torrents with active seeders/peers can be downloaded.
dht is only used when needed, and only if you, the tracker, and at least one of your peers has enabled it.
Ty going through our settings guide for BC. From the sounds of things this is most likely a frewall issue.
My bitcomet client doesn’t download all the torrents. Can any of u guys tell me how i can determine if it is a firewall problem. And if it is how i can by pass the firewall?
Another point is , my computer is part of a network. I have noticed that bitcomet doesn’t download in all of the computers in the network
i have the same problem my DHT is no connected i need help…damn
if you have the windows firewall, go to Control Panel → Windows Firewall → Exceptions (a tab) → tick the boxes to to make exceptions for bitcomet
