Downloaded Torrents are storing on HD as "File" rather than AVI, Xvid, ect
Hi, I am using bitcomet version 1.32.
On various torrent/Magnet downloads the finished file does not store as it normally would.
i.e. in the downloaded directory most of my files download as normal where it shows as a yellow folder of what i have downloaded and then when you click on the folder you get the video file inside the folder.
However a few downloads are just showing as “File”. So rather getting the usual yellow folder symbol i am getting what looks like a blank page symbol (Small white Rectangular shaped symbol)
You can still open the file and chose what programme you would like to use to open it. It still allows you to view the video file this way.
However if you try and convert the file to disk. No software recognises the file.
Is there anyone else having this issue and if so is there a fix for this
Thanks
V
http://www.cometforums.com/topic/12797705-downloaded-files-missing-their-extension/page__view__findpost__p__67368
