downloads.xml
Hi i used to use download.xml file to send myself the the download
info when i am away. But ever since i switched to 0.7 version the
downloads.xml file doesnt update itself. Although the torrents have been
fully downloaded the xml file doesnt show the change. Well i might have
to switch back to 0.59 version if the problem isnt solved.
you cant expect to upgrade from 0.59 to 0.70 without any problems.
these are 11 versions. Make a clean install and everything should be ok
I am downloading every new version and I haven’t problems with this at all.
