DRM Steams
Why on earth would anyone put a DRM file on bitcomet, that required a conversion program like Aimersoft…to be able to use it, unless it was to sell a DRM Stream converter program, more to the point why would bitcomet allow it. Jus sayin seems a bit odd, any comments on this would be greatly appreciated.
BitComet has nothing at all to do with this, your complaint should be focused at whatever torrent site you found this download at. BitComet is simply download software, where you find the files you want to download is between you and the website you used.
I’ll also caution you that if a torrent asks you to buy or install anything, it’s surely a scam and you should delete the files, report the torrent, and find another.
