Edit trackers for few files at the same time
Hello Guys
				Wanted to say thank you very much for that great job you made to create your torrent client.
				Also I wanted to ask you to add one useful feature. If it's possible, please could you allow to change trackers for few files at the same time.
				For example:
				1) User highlight 10 files
				2) Press on these files right button of the mouse
				3) Press "Edit trackers"
				4) In opened window set needed trackers
				5) Press "Ok"
				Done, trackers was changed for all 10 files in the same time.
				Also, in the point 4 you could add checkbox: "Add to existed trackers"
				It will means trackers will not be replaced but just will be added like additional.
				Thank you in advance.
