Hey,I’ve been using bit comet for about 2 years now and I’ve never had a problem with it.Sadly,two days ago,my bit comet listen port changed automatically but all that took was to re-portfoward it again.But now i cant seem to sign in,it keeps telling me “Unable to sign in CometID at this time.” Any suggestions or idea ?
Thanks in advance
Hi, sorry your post was overlooked.
Are you still having trouble signing in? Your port issues shouldn’t effect your ability to sign into comet ID.
Also, the reason your portforward rule no longer worked isn’t that the port changed, most likely this was because your IP address changed. Setting a static IP address in windows will prevent this from happening in the future.
That is the most common explanation for the behavior you report.
