extracted Help
Hey appreciate all the help just got a small problem .
Then i extract it to my hardrive but when i go and delte the rarar folder it says error folder being used by another person or program
any help
appreciated
This is windows file protection at work hehehe…
Microsoft built this into its newer operating systems, but it drives people crazy sometimes.
If the torrent is still loaded in your client, then you will not be able to delete the files.
Please be sure you seeded a minimum of 1:1 before you delete the .rar files.
then remove the torrent, and close your client, and you should be able to delete the files.
Worse case you may need to reboot.
If you are comfortable with doing so, you can disable windows file protection, type that into a google search and there are many guides posted.
Do this only if you know better then to delete important files, if your not sure, then DO NOT do this.
